Date/Time: Fri, 07 Feb 2025 15:02:25 +0000
Bonjour
View Count: 877
[2020-05-20 14:19:15]
Pierre homme DESBIOLLES - Posts: 4
J'aimerai prendre une position en manuel et sortir avec un SuperTrend par exemple, comment puis-je paramétrer ceci?
merci d'avance
Pierre
[2020-05-20 19:42:10]
From Google Translate
I would like to take a manual position and go out with a SuperTrend for example, how can I configure this?
We are not sure exactly what you are looking for in terms of a SuperTrend, but it sounds like you first need to be aware of the Attached Orders within Sierra Chart which allow you to add a Target and Stop to your manually placed position. Refer to the information here:
Attached Orders
And specifically take a look at the following section within that page that gives you information on how to control the Targets and/or Stops using a study:
Attached Orders: Study Controlled Targets and Stops
[2020-05-21 06:25:58]
Marmany - Posts: 308
What you are probably looking for is known in Sierra as Super Trend Stop. It is available as a standard indicator and in spreadsheet format.
Super Trend Stop
This indicator was developed by Olivier Seban, a French futures trader. It gives a trend indication second to no other indicator, but suffers from the universal problem of giving false signals in non-trending, consolidating markets.
[2020-06-03 10:01:37]
Bonjour,
Détail de ma demande:
1) Prendre une position en manuel (pas de problème pour ça)
2) Sortir de positon avec une studies ( par exemple un super trend ou une moyenne mobile)
Merci d'avance pour vos réponse.
Pierre
[2020-06-04 06:43:27]
From Google Translate:
Details of my request:
1) Take a position manually (no problem for that)
2) Get out of position with a study (for example a super trend or a moving average)
Thank you in advance for your answers.
Pierre
Refer to the following that gives you a way to automatically adjust your Target or Stop based on a study:
Also refer to the following for Attached Orders:
Attached Orders
If you are not wanting to use Attached Orders to manage your position, then you would need to create your own Automated Trading Study using the ACSIL interface. Refer to the following for an introduction:
Automated Trading Management
[2020-06-05 11:35:57]
Bonjour,
Merci pour votre réponse, c'est parfait, ça fonctionne.
Merci beaucoup
Pierre
