Date/Time: Fri, 07 Feb 2025 04:55:10 +0000
"Add additional symbol" study's volume is not correct
View Count: 670
[2020-05-20 12:43:22] |
mayi_china - Posts: 3 |
Hi, when I use the study of "add additional symbol" to the chart,I found that the volume of the added symbol is not correct, is only a constant number to all bars. please check it, thank you. http://www.sierrachart.com/image.php?Image=1589978483105.png |
[2020-05-21 18:41:38] |
We will be looking into this and resolving.
[2020-05-21 23:47:51] |
Thank you so much.
[2020-05-22 14:07:23] |
Update to version 2019: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-24 00:50:27] |
Thank you very much.
