Date/Time: Fri, 07 Feb 2025 05:01:17 +0000
DOM DPL
View Count: 865
[2020-05-19 23:58:04] |
User575399 - Posts: 326 |
Is there a way to change the DOM DPL color Or remove the color making it white ? I have my NPL and DPL turned off ( unchecked) I don’t like to see any P & L on my DOM ( it can affect my decision making ) thanks !
[2020-05-20 10:07:49] |
Yes there are full-color settings for this. This is controlled through Graphics Settings: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-20 10:28:26] |
I tried that. I didnt see a color setting for that. I even tried changing all the dom settings to white. Still nothing. Here is the part im talking about . see attached pic
[2020-05-22 15:35:29] |
The relevant color settings are very well explained in this section and the following two sections: Basic Trading and the Trade Window: Main/C >> Position Quantity@Price: / P: (Compact tab) (Main/C >> Position Quantity@Price: / P: (Compact tab)) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-22 15:36:07
