Date/Time: Fri, 07 Feb 2025 02:01:32 +0000
DOM Flashing in and out of current price range
View Count: 477
[2020-05-19 15:56:41] |
User645429 - Posts: 4 |
Hi, Have latest version of SC running. For no apparent reason my ES DOM has suddenly started alternating between displaying where the current price is (Normal) and a price that is 30+ points lower. It does this every 2 seconds making it impossible to place or manage a trade. I have exited and reentered SC several times but with no change. Can you please assist? Thank you
[2020-05-19 18:31:25] |
This is now resolved. It was a problem with the data feed with an out of date price on the ask side at the top of the market depth array. We are looking into why this has happened and implementing a solution.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-19 18:39:04
