Date/Time: Fri, 07 Feb 2025 01:51:24 +0000
Web-Based Trading Panel
View Count: 2768
[2020-05-19 15:53:34]
ondafringe - Posts: 298
Yesterday, I requested, and received, authorization to access/use the Web-Based Trading Panel. When I attempt to access that panel using this link:
https://www.sierrachart.com/UserControlPanel.php?page=TradeAccountDataAndOrderEntry
I get a message indicating this feature has not been enabled for my account.
When you have a few minutes, would you check this for me?
Thanks,
George
[2020-05-19 19:18:53]
The web-based trading panel only works with this service:
Sierra Chart / Trading Technologies Futures Order Routing Service
It does not work with any other service other than the simulated trading services that Sierra Chart provides.
[2020-05-19 19:23:12]
Okay. I had a feeling that was the problem. Since I use Rithmic, and SC will pull the plug on Rithmic at the end of the year, I will be switching to TT/Denali shortly.
Thanks,
George
