Date/Time: Fri, 07 Feb 2025 06:49:44 +0000
Placement of Trade Window....!
View Count: 2173
[2020-05-19 13:28:07] |
User318781 - Posts: 5 |
Hi, how can I put the order panel/window to the right hand side of a chart?
[2020-05-19 14:43:30] |
mrad - Posts: 7 |
In Chart Settings under the Advanced Settings tab there is an option "Attach Trade Window to Right Side" (it's somewhere on the right hand side)
[2020-05-19 15:23:15] |
Thank you very much! Do you know by any chance whether I could have the DOM without all those buttons, pure so to say?
[2020-05-19 15:33:19] |
mrad - Posts: 7 |
In the Trade menu click "Attach Trade Window To Chart Window" to detach the trade window. After that you can simply close the trade window.
[2020-05-19 15:46:20] |
Thank you again mrad-2! To detach the trade window located next to the DOM is not possible, is it?
[2020-05-19 15:53:39] |
mrad - Posts: 7 |
Yes, it is. The DOM window also has a Trade Menu with the menu item "Attach Trade Window To Chart Window".
[2020-05-19 16:08:41] |
I found it! Thank you very much and have a nice day!
[2020-05-19 19:06:21] |
Refer to the following setting: Chart Settings: Attach Trade Window to Right Side (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-21 21:17:41] |
Good evening mrad-2, I am turning to you again with the following question: I do have a Trading DOM on the right hand side and I do have a "small little DOM ladder" configured on my Chart. I did manage to find out how to set the type of stop I am using on the "big DOM" to stop limit all by myself. Could you kindly tell me how I could do the same for the DOM ladder on the chart. That would be very nice!
[2020-05-24 23:10:52] |
The Chart/Trade DOM order types are a global setting and apply to all Chart/Trade DOM interfaces: Global Trade Settings Windows: Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-25 12:53:01] |
mrad - Posts: 7 |
If you mean how to have the same trade configuration (stop and target settings) on your chart DOM and your "big DOM", I always link the chart and the "big DOM". To do this go to Chart Settings - Advanced Settings 2. Under Chart Linking you should at least choose the same Link Number and check Symbol and Trade Window. You have to make these settings on both your chart and the "big DOM" and then they are always synchronized. |
[2020-05-26 01:35:13] |
Yes we understand that. Check the order types in the Chart DOM Settings to make sure they are set as you require: Global Trade Settings Windows: Chart DOM Settings If you still need more help, can you tell us exactly how you are submitting the order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
