Date/Time: Tue, 04 Nov 2025 18:18:17 +0000
Chart Issues
View Count: 2398
| [2013-04-15 20:56:44] |
| User88901 - Posts: 33 |
Hi, I cannot figure out how to display for example a 1min SPY chart with the NYSE Tick right under it like an indicator. I linked the symbols and they scroll together I just want them to be in the same chart so that as I increase or decrease the time period they will both do it and look the same. Not just scrolling 2 different charts. Thanks.
| [2013-04-15 21:09:22] |
This is explained at the bottom of this page: http://www.sierrachart.com/index.php?l=doc/helpdetails66.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
