Date/Time: Fri, 07 Feb 2025 02:07:19 +0000
Add Backup feature
View Count: 506
[2020-05-19 11:40:32]
User189132 - Posts: 63
Can you add Backup feature where user can back up all its settings and chart's definitions to location selected by user?
User can also be prompted to back up when he closes SC, the same way how user is prompted with "Save All"
Thank you
[2020-05-19 18:15:26]
This happens automatically. There is nothing special to do. The files are in the Backups subfolder.
