Date/Time: Fri, 07 Feb 2025 02:16:14 +0000
Can I configure Alert popup from a chart instead of Alert Manager window?
View Count: 628
[2020-05-19 10:54:29] |
User189132 - Posts: 63 |
Hi, Can I configure an Alert popup from the chart instead of going to Alert Manager Window? Thank you. |
[2020-05-19 19:41:53] |
The choice of the Popup Window associated with an Alert is done on the Alerts tab of the General Settings window. Refer to the information here: General Settings Window: Add Alert to Compact Alert Popup Window (Global Settings >> General Settings >> Alerts >> Additional Settings) All you need to do is set the Alert itself to use the Popup Window and then any place where that Alert Number is used will give you the Popup Window when the alert is true. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
