Date/Time: Fri, 18 Sep 2026 15:37:34 +0000
Session Highlight
View Count: 990
| [2020-05-19 03:40:27] |
| User161806 - Posts: 18 |
Hi there, I'm curious to know if there is a study which highlights the 'open' and 'close' for a country's market eg: - Australia, Japan, Hong Kong etc. I have been using time range highlight and manually entering the open and close times for each market. Just wanted to see if i may potentially be missing something. Thanks very much for your time. Kind Regards, Josh |
| [2020-05-19 07:37:30] |
That is a good way to do it. There is also the vertical grid which can be based upon the session times: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
