Date/Time: Fri, 07 Feb 2025 02:01:22 +0000
Any limitations or processing or ram tested?
View Count: 1180
[2020-05-18 22:56:09]
Chadly - Posts: 65
My plan is to run 100 different NYSE chartbooks and 30 forex chartbooks and probably around 20 "others" at the same time on the same machine firing alerts.
Are there limitations to observe to then build my machine around/accordingly in order to handle the demand needed?
Also, as there are email limitations around how many emails can be sent, how do I get around that? if I have 100 tickers and 50 or so other chartbooks all firing alerts, there certainly will be way too many alerts even per hour and will exceed the limitations. How do I make this limitation not an issue?
Thanks for your help as always!!
[2020-05-19 07:35:25]
Regarding sending emails, we want you to use your own solution for that. Maybe use libcurl:
https://curl.haxx.se/libcurl/
Which you can interact with from ACSIL:
Advanced Custom Study Interface and Language (ACSIL)
Otherwise, you are going to have limits sending email from our own systems.
And you will want to use multiple instances of Sierra Chart for this:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
We would recommend an 8 core machine with 32 GB of memory.
Date Time Of Last Edit: 2020-05-19 07:36:16
