Date/Time: Fri, 07 Feb 2025 01:59:07 +0000
"Non-Attached Limit Order Tick Up/Down" and "Send Attached Orders Position"
View Count: 758
[2020-05-18 21:30:33]
j4ytr4der_ - Posts: 946
I'm not sure if I am misunderstanding something, or if there is an undesired behavior.
My interpretation of "Send Attached Orders Position", is that when it is selected (assuming the current position has no attached orders) it will attach the selected orders from the Trade Window (in my case a bracket with 1 stop and 1 target). At this point, those orders should now be attached to the original position.
Assuming the above is correct (and if it is not, please correct me), then using the "Non-Attached Limit Order Tick Up/Down" shortcuts, should do nothing since there is no non-attached order present.
In actuality, "Non-Attached Limit Order Tick Up/Down" will in fact move the target portion of the bracket.
Am I doing something wrong or misunderstanding how this is supposed to behave?
[2020-05-19 07:48:24]
That would make sense because those orders have no parent order. They are not attached to the position. The position only established the price.
[2020-05-19 12:10:27]
OK, but the name of the function is "Send Attached Orders Position". That seems to imply that the orders will be attached after they are sent. The name of the function is not "Send Non-Attached Orders Position". See what I mean? Makes it seem like it's not behaving correctly. At least now I know it's expected behavior.
