Date/Time: Sun, 04 Oct 2026 02:46:23 +0000
Attached orders with BitMex
View Count: 1036
[2020-05-18 21:29:33]
User980227 - Posts: 7
Hi Sierra Chart team,
I am using attached orders with BitMex.
Once a parent order is filled, the attached stop loss and profit target become active.
Let's say a very rare event occurs, such as I manually cancel the stop loss via BitMex.
Is there a way of identifying this situation within SC where I have an open position with a missing attached stop?
So far I have failed attempting to identify a change in order status with below lines.
s_SCTradeOrder TradeOrderData;
int OrderStatusStop = sc.GetOrderByOrderID(StopInternalOrderID, TradeOrderData);
sgStatusStop[sc.Index] = (float)OrderStatusStop;
Thank you very much for your help.
Sebastian
[2020-05-19 19:17:23]
If there is a status change, the study function will be called and you need to access the status through this member variable:
Automated Trading From an Advanced Custom Study: [Type: integer] OrderStatusCode
And if the order is not found it, it means it no longer exists.
Date Time Of Last Edit: 2020-05-19 19:18:08
[2020-05-26 12:29:32]
Thank you for pointing me in the right direction.
Other question please, I have the following options enabled :
- (1) "Auto-Send Market Order on Rejected Stop Attached Order"
- (2) "Reactivate Attached Order when Rejected Modification During Fill"
I understand when an order is rejected, it gets the status of SCT_OSC_ERROR.
But when (1) or (2) happen, does the order status change or does it remain SCT_OSC_ERROR ?
[2020-05-29 15:51:53]
1. Stays as SCT_OSC_ERROR
2. Will change to current status of reactivated order.
