Date/Time: Tue, 08 Sep 2026 17:04:48 +0000
Volume Dist paint bar study
View Count: 2023
| [2014-01-21 22:43:36] |
| pse52 - Posts: 18 |
Is there a document that explains the details of the various colors and how to read them in this study? It looks very similar to a chart in Inside Edge/CN Futures but there are some differences. I'm specifically trying to understand why on some bars the black outline is not completed at one end or the other and it seems to happen consistently when the mode (brown coloring) is extended at the top or bottom of the bar
| [2014-01-23 00:51:37] |
If you do not see the study listed in the Technical Studies Reference documentation, then there is none.
| [2014-01-23 01:49:18] |
| pse52 - Posts: 18 |
It there but it doesn't really say anything other than you can change colors.
| [2014-01-23 07:38:58] |
We will have to improve upon the documentation.
