Date/Time: Fri, 07 Feb 2025 01:56:35 +0000
Totally Frozen
View Count: 660
[2020-05-18 14:42:57]
buggsuperstar - Posts: 33
Yesterday I was getting a message that I was running out of disk space. This morning I shut down my computer and rebooted and now Sierra Chart connects but does not update charts. No live data is flowing. I would appreciate your support thank you!
[2020-05-18 15:02:35]
I just found out that the symbols have changed. My charts have been working correctly for a month with ESM20_FUT_CME and now that symbol for live data is ESM20. I have not made any changes to my data feed I should still be on Denali. Do you know what happened?
[2020-05-18 15:20:15]
I have also found that my time zone settings have changed and when I tried to switch back to Chicago time it says the config file size is much smaller than the expected and it might be corrupt.
[2020-05-18 15:23:14]
I found that I need to free up space on my computer. I will do that and report back!
[2020-05-18 15:46:00]
Do you have any recommendations on how to run SC without needing as much storage space?
[2020-05-18 16:07:27]
Sierra Chart is currently running at 14 GB on my drive.
[2020-05-18 16:39:32]
John - SC Support - Posts: 37808
Start with the information here to clean up any old Symbols:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
Then make sure you follow the link in Step #7 that takes you to Deleting Chart Data Files.
[2020-05-18 17:47:47]
Also refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.12 - Intraday Data Storage Time Unit. Historical Data Record Time Frame.
Regarding the symbols, like ESM20_FUT_CME, make sure Sierra Chart is set to use the Sierra Chart order routing service:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
And be sure to translate the symbols back again to Edit >> Translate Symbols to Current Service.
Refer to:
Data/Trading Service Connection and Symbol Issues: 1.3. Symbols
Date Time Of Last Edit: 2020-05-18 17:48:09
