Date/Time: Mon, 25 Nov 2024 06:30:26 +0000
Moving charts from screen to screen:
View Count: 1093
[2014-01-21 22:20:15] |
User22591 - Posts: 133 |
My account should allow me to move my charts or symbol from screen to screen but it is not allowing me to do so. Please advise. |
[2014-01-22 01:00:39] |
So you are not able to detach them using the Detach/ Attach command on the Chart or Window menu?
