Date/Time: Fri, 07 Feb 2025 01:55:09 +0000
Trading DOM for Butterfly spreads
View Count: 585
[2020-05-18 10:48:18] |
EthanC90 - Posts: 6 |
I have set up the butterfly spreads, but the trading DOM does not seem to link to the spreads. Any advise? |
[2020-05-18 17:32:29] |
What is the symbol of the spread. And did you want to trade these live? Or just simulated? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-19 05:57:59] |
ZN Fly 1*{ZNM20}-0.63*{ZFM20}-0.25{ZBM20} NOB 5*{ZNM20}-2*{ZBM20} Kindly refer to attached, both Market depths are empty on SIM. |
[2020-05-19 12:14:06] |
There will not be any market depth data for Custom Calculated Symbols.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-19 18:47:50
