Date/Time: Sat, 15 Mar 2025 03:52:09 +0000
Scrolling up and down
View Count: 1496
[2020-05-18 10:45:16] |
user2837 - Posts: 76 |
By default, the up arrow and down arrow keys are bound to functions to adjust spacing between bars. Is there a way to rebind them to make the window scroll up or down. Perhaps something under Global Settings ---> Customize Keyboard Shortcuts?
[2020-05-18 10:47:15] |
No this is not supported but what you can customize is the Scroll Wheel: General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-11 13:59:51] |
User223281 - Posts: 58 |
is there a way to set the up and down arrows of the keyboard to scroll the verticle scale of a chart?
[2022-07-11 18:12:14] |
John - SC Support - Posts: 38678 |
There is not a way to do this.
