Date/Time: Fri, 07 Feb 2025 00:41:09 +0000
Scrolling Desktop Feature, How to set 4 x the Height of the screen?
View Count: 506
[2020-05-18 07:53:26] |
User14953 - Posts: 241 |
Scrolling Desktop Feature is set to - On the Desktop is sized for 2 x the Height of the screen in use. Always works great. How would the Desktop be set to 4 x the Height of the screen in use? I only have two monitors attached. |
[2020-05-18 07:58:19] |
We are not providing support for that feature until it is reimplemented by us. It currently uses functionality at the operating system level which is unreliable.
