Date/Time: Fri, 07 Feb 2025 19:41:01 +0000
Sierra Chart/Denali Exchange Data Feed Users Require 2060 or Higher Effective June 15, 2020
View Count: 1414
[2020-05-18 00:49:15] |
A required update for users of the Sierra Chart/Denali Exchange data feed is going to be required June 15, 2020. You will need to be running version 2060 or higher before then. Prior versions are going to be locked out if you are using either of these data feeds. Thank you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-18 03:39:07
[2020-06-13 01:15:25] |
This has now gone into effect.
