Date/Time: Fri, 07 Feb 2025 01:06:09 +0000
Dorman through TT setup.
View Count: 948
[2020-05-17 19:15:53] |
User940666 - Posts: 6 |
Dear Support, I just switched my Dorman account from Rithmic to TT and having some trouble setting up the connection. Could someone please help me to set up? I think I just need deafult server address and port for Dorman. Unfortunately I do not think my broker has had enough experience with TT either, that's why I am asking. I gone through https://www.sierrachart.com/index.php?l=doc/TradingTechnologies.php , but have not been able to get things done. As of now, my message log says that Price Session Server and Port setting incomplete. Thank you. |
[2020-05-18 05:58:06] |
You need to complete this form: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm And you do not use TT FIX directly. The instructions are here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-18 06:59:35] |
Thank you a lot for fast and informative response. I just completed the form.
