Date/Time: Fri, 07 Feb 2025 01:50:45 +0000
[User Discussion] - Day trade US equities with IB
View Count: 586
[2020-05-17 14:21:09]
vish100 - Posts: 111
I am planning to day trade US equities with IB broker.
Can I use SC data feed with US equities exchanges enabled and IB as broker? I plan to use only level 1 data.
Is it OK to do considering you do not recommend IB.
If IB is not recommended, which broker should I use?
thanks
Vish
[2020-05-19 06:12:39]
Hi - would appreciate a reply thanks
[2020-05-19 20:53:25]
lw - Posts: 11
I am also curious about the answer.
Date Time Of Last Edit: 2020-05-19 20:53:44
[2020-05-19 23:37:07]
UserAR - Posts: 64
I have been using Sierra with IB data feed with Level 1 to day trade equities for the past year. Works fine. Just don't use IB data feed as it is horrible.
