Date/Time: Mon, 25 Nov 2024 12:50:15 +0000
Litetree Data Feed?
View Count: 1305
[2014-01-21 18:40:22] |
User98214 - Posts: 4 |
I know little about programming and am trying to make sense of Sierra Charts ACSIL feature and usefulness. I talked to Litetree about getting their data feed listed with Sierra Chart but they told me the API they provide is already capable of this; it is a small set of php scripts. Is it possible to program their php scripts into my chart to create a feed? Or does this fall under "api is no longer supported"? Thank you!
[2014-01-21 20:02:49] |
Either they can adopt DTC or you can do this yourself by developing a bridge program. Please have a look at this page: https://www.sierrachart.com/index.php?l=doc/doc_GeneralDataTradeServiceProtocol.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-21 20:03:16] |
Is this a bitcoin data feed? Just curious.
[2014-01-21 20:47:53] |
Thank you if the bridge program isn't too far over my head I will give it a try. They are a fairly new US based bitcoin/litecoin exchange, I will link them to your DTC page in hopes of motivating them to port it
[2014-01-21 20:57:35] |
Yes. They definitely should. And we can also work with them to implement a version of DTC which uses an HTTP type connection and JSON if that would help. We are happy to do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-12 02:55:31] |
Well I am tired of waiting for these exchanges who claim to be working on implementing DTC so I think I will take a stab at messing with it myself. What exactly do I need to teach myself in order to make Bitcoin exchange API's compatible with Sierra Chart? I know a bit about C++ (about as much as a year one CS student) and am convinced I could figure this out but I don't know where to start. Is it realistic for me to teach myself how to do this by researching JSON/PHP and using the Rithmic Bridge Source you provide or am I in over my head?
[2014-02-12 19:10:29] |
We think it is realistic for you to do it. Really beyond the documentation here, we really cannot provide further help: http://www.sierrachart.com/index.php?l=doc/doc_DTCMessageDocumentation.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-12 19:10:47
