Date/Time: Tue, 11 Feb 2025 01:39:24 +0000
web trading setup
View Count: 692
[2020-05-16 21:09:17] |
User525965 - Posts: 153 |
how do i enable trading off the website?
[2020-05-16 21:39:33] |
You need to switch to this service: Sierra Chart / Trading Technologies Futures Order Routing Service You cannot use CQG or Rithmic for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-16 21:39:42
[2020-08-30 18:04:28] |
Hello, now that i have Denali data feed setup, is here anything else i need to do to be able to modify or place new order via the web platform? Amp is my broker. thanks! Also, have a simulated tryout acct with someone else, can i do the same here or does it need to be an actual live acct? |
[2020-08-30 20:48:52] |
John - SC Support - Posts: 37869 |
As stated previously, it is not about the data feed, you need to be using the Sierra Chart Order Routing Service in order to use the Web Panel that we have available. It only works with that particular service. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel and more generally, that entire page: Sierra Chart / Trading Technologies Futures Order Routing Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
