Date/Time: Fri, 07 Feb 2025 00:47:08 +0000
Cumulative Delta Study Angle
View Count: 870
[2020-05-16 21:05:07] |
Unicorn_Catcher - Posts: 22 |
I am trying use "Study Angle" study to measure the Cumulative Delta Bars study, but it only outputs +89.xxx or -89.xxx, essentially behaving as a simple pos/neg slope determination. This happens whether I have based the angle on Cumulative Delta Bars study itself or on smoothed studies of that study (Heiken Ashi, MAs, etc) and is the same for all Lengths tested. Basing the angle study on the main price graph gives actual angles ranging from 90 to -90. Is Cumulative Delta not compatible with this study? Or do I need to run it through another study first to get accurate angle readings for Cumulative Delta? Thanks Date Time Of Last Edit: 2020-05-16 21:05:59
[2020-05-17 12:50:19] |
You need to read the documentation for that study: Study Angle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
