Date/Time: Thu, 06 Feb 2025 23:55:57 +0000
Where is unique 16 byte integer Market Data Request in s_MarketDataRequest structure?
View Count: 659
[2020-05-16 20:53:35] |
donnicky - Posts: 33 |
Hello. Manual https://www.dtcprotocol.org/index.php?page=doc/DTCMessageDocumentation.php#MarketData references unique 16 byte integer Market Data Request, but I cannot see any in s_MarketDataRequest. Is it uint32_t SymbolID what is meant? https://s3.amazonaws.com/donnicky_screenshots/2020-05-16_23-49-05_7751ab38-f58a-43bc-9cca-f2a89655865f.png |
[2020-05-16 21:54:17] |
That documentation was out of date and is now updated. Is it uint32_t SymbolID what is meant? Yes.
