Date/Time: Mon, 25 Nov 2024 07:44:21 +0000
cancdlesticks in dailycharts
View Count: 1282
[2014-01-21 18:22:12] |
BTSV4ever - Posts: 14 |
I am missing the daily canclesticks from 2014-01-01 to 2014-01-20 in CL, GC and EUR. The candlesticks of 2013 and candle of today are ok. Sierra Version is 1076, Datafeed is IB Can you help me please. Thanks, Matthias |
[2014-01-22 01:35:29] |
Go into each chart and select Chart >> Chart Settings . Press the Find button beside the Symbol box and reselect the symbol.
[2014-01-22 02:29:27] |
We have added a new help topic section 6.7, here about this: Http://www.sierrachart.com/index.php?l=doc/helpdetails6.html In any case, help topic 6 in general should give you the information needed to solve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-22 02:29:44
[2014-01-25 11:50:24] |
works, thank you!
