Date/Time: Fri, 07 Feb 2025 00:26:56 +0000
[User Discussion] - volume ratio
View Count: 727
[2020-05-16 10:01:44] |
User338356 - Posts: 8 |
hi, it's possible to create the ratio volume/trade on each level? For example a large order on ES 220 contract in to the bid @ 2800. i want to see the ratio volume/trade. 220 with 1 trade is 100% or calculated 220 or if it divided in 3 trades (100+100+20) or (70+70+70+10) ecc ecc and calculate this ratio? maybe in a time and sale or in number bars study thanks Date Time Of Last Edit: 2020-05-16 10:04:08
[2020-05-16 10:06:59] |
hi, it's possible to create the ratio volume/trade on each level? For example a large order on ES 220 contract in to the bid @ 2800. i want to see the ratio volume/trade. 220 with 1 trade is 100% or calculated 220 or if it divided in 3 trades (100+100+20) or (70+70+70+10) ecc ecc and calculate this ratio? maybe in a time and sale or in number bars study thanks |
[2020-05-16 10:10:29] |
Ackin - Posts: 1865 |
The result value is the accumulation (sum of all ratios) on one level?
[2020-05-16 12:12:19] |
The result is the ratio at that level. example If in a number bars with filter volume exclude <= 100 contrats: 0x0 0x220 0x0 I want know in that order how many order and ratio if 1 (220) order ratio 100 2 order (110+110) ratio 50 or calculated ratio if this order hit with 2,3 or more order. In example 2 the ratio is different if i ve 2 trades (190+30). I hope you understand what I mean |
[2020-05-16 12:15:55] |
I'll think about it and create a study for it (+ - will be available for download on Monday)
[2020-05-16 12:20:35] |
Thanks so much!!
