Date/Time: Fri, 07 Feb 2025 01:01:23 +0000
Spreads historical Data
View Count: 828
[2020-05-16 07:38:16] |
EthanC90 - Posts: 6 |
Have found that the spread data is only for the contract month. If thats the case, are there any ways to view historical data via comparison? i.e FYT (ZF*3-ZN*2) |
[2020-05-17 12:52:21] |
You can get expired exchange traded spreads as well well. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads You will need to use the Denali Exchange Data Feed : Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-17 12:52:41
