Date/Time: Fri, 07 Feb 2025 00:27:02 +0000
How to overlay VbP from 24-hour TPO on fast chart
View Count: 726
[2020-05-16 00:38:05] |
Bedhog - Posts: 179 |
Hello Team, I want to overlay the peaks and valleys from a TPO chart onto a fast chart. The left window is a 24hour TPO chart that begins at 17:00 CST with 2 increment spacing. There is a VbP study with peaks and valleys extended to end-of-window. The right window is a 1 minute chart. The Study/Price Overlay does not work for the VbP, so I saved the VbP study collection from the TPO and then applied it to the 1 minute chart. I added the 2 horizontal lines (yellow dash) for reference / vertical spacing. The peaks and valleys on the fast chart do not align with the TPO chart. How can this be accomplished? Thank you. --update-- I solved it by setting the Volume Graph Period Type = From Session Start Time to End Thank you! Date Time Of Last Edit: 2020-05-16 01:14:04
24-HR-VBP-ON-A-FAST-CHART.PNG / V - Attached On 2020-05-16 01:13:43 UTC - Size: 58.25 KB - 269 views Attachment Deleted. |
