Date/Time: Fri, 07 Feb 2025 01:16:34 +0000
Request activation of Real Time Data Feed
View Count: 635
[2020-05-15 20:39:26]
Chadly - Posts: 65
Good morning!
I Just put in a request to active the NYSE real time data feed. Can I Get that activated please?
Chadly
[2020-05-16 02:15:27]
We apologize for the delay .
This is now done. You can activate the exchanges now:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures
Date Time Of Last Edit: 2020-05-16 02:15:51
[2020-05-16 11:30:35]
Chadly - Posts: 65
Thank you! No sweat on the delay, I get it.
I read a comment that may be obsolete now, but it mentioned that I needed to download a totally different instance of Sierra Chart then put it in a different folder and run both instances.
I mainly trade forex so I would have one instance with forex tabs and forex datafeed. Then I'd have another instance for stocks? Is that not necessary anymore I hope?
Can I just have SC Data - All Services selected instead and run both forex and NYSE on my charts on one instance?
[2020-05-17 12:54:25]
Yes this is definitely the case for at least about 8 years now.
[2020-05-17 12:58:30]
Chadly - Posts: 65
Thank you! you guys are great, thanks for being able to keep support open during the VID
