Date/Time: Tue, 29 Sep 2026 17:02:57 +0000
PLACE TRADE USING KEYBOARD SHORTCUT
View Count: 6567
| [2020-05-15 16:48:07] |
| sjbenn85 - Posts: 11 |
Dear Sir/Madam, Please could you tell me how to place a trade with a keyboard shortcut....? Your hep would be much appreciated. Best Regards Simon |
| [2020-05-15 23:08:05] |
| Ackin - Posts: 1865 |
1) check: Menu >> Trade >> ... chart Trade Mode ON (Enabled) Trading Locked (Disabled) Trading Keyboard Shortcuts (Enabled) 2) Global Settings >> Customize Keyboard Shortcuts 1. Select Global Settings >> Customize Keyboard Shortcuts. 2. In the Commands list, choose the particular menu command that you wish to set up a keyboard shortcut for. 3. Choose the particular key in the list of keyboard keys and the key modifiers (Control, Alt, Shift) to assign to the Selected Command. 4. Note: Do not use individual letters and numbers for keyboard shortcuts without a modifier (Control, Alt, Shift). Keyboard shortcuts are handled at the operating system level and you will lose use of these individual letters and numbers that you use if you are not using a modifier. For example, if you use the number 1, you will not be able to type 1 any longer within Sierra Chart text boxes. 5. Press the Assign button to assign the chosen keyboard shortcut to the Selected Command. Customize Keyboard Shortcuts Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) 3) Search Item "Trading Keyboard Shortcuts" in the list According to the previous point above(2), find the command and assign a keyboard shortcut for it 4) Test it ;) |
| [2020-05-16 00:09:01] |
Refer to the documentation here: Basic Trading and the Trade Window: Trading Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
