Date/Time: Fri, 07 Feb 2025 00:28:08 +0000
[User Discussion] - Visible Range VbP on TPO chart
View Count: 1714
[2020-05-15 12:59:51]
User223281 - Posts: 58
Hello, I would very much like to add a visible bars Volume by Price to my TPO chart, in addition to the daily volume. When I try to add a second VbP it just puts it on top of the daily one, and wont let me select "visible bars". I've included a chart with a drawing to give clarity to my idea.
imageScreen Shot 2020-05-15 at 6.58.44 AM.png / V - Attached On 2020-05-15 12:59:43 UTC - Size: 79.74 KB - 453 views
[2020-05-16 13:22:33]
SKZ90 - Posts: 74
Make sure you enable this function.
Volume By Price Study: Set as Independent Volume Profile for TPO Chart
Then you can use this setting to make the composite volume smaller, so it doesn't fill your screen so much.
Volume By Price Study: Maximum Volume Bar Width Percentage
Date Time Of Last Edit: 2020-05-16 13:23:37
[2020-05-16 13:54:48]
Thank You! Do you know if there is a way to set the VbP period to Visible Bars? Seems like it will only do fixed time.
[2020-05-16 14:18:15]
SKZ90 - Posts: 74
I've attached a picture. This is what you're looking for? The composite volume on the right can be set to "All Bars In Chart"
imageimage.PNG / V - Attached On 2020-05-16 14:16:59 UTC - Size: 149.05 KB - 512 views
[2020-05-16 14:22:44]
Yes this looks good. Close as I will get to to visible bars. Thanks for your help!
