Date/Time: Fri, 07 Feb 2025 00:27:32 +0000
Daily p/l problem
View Count: 511
[2020-05-15 11:34:56] |
Kza57 - Posts: 13 |
Hi, I've got a problem with orders fill. For example : I opened a short position but it appears like a closed postion, as you can see on the attached image. In fact my daily P/L is totally wrong. It only appears on rithmic live account, sim is ok. How could I reset it please ? |
![]() Attachment Deleted. |
[2020-05-15 11:53:02] |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
