Date/Time: Fri, 07 Feb 2025 00:29:27 +0000
Activation of the service
View Count: 505
[2020-05-15 10:29:35]
User578161 - Posts: 5
I have a new account with the broker AMP.
I would like to operate the the mini Dax future.
Where can I find it to activate the service.
Thanks for you support
[2020-05-16 00:05:20]
The Mini DAX is traded on the EUREX. In order to get Real-Time data for the EUREX you need to use the Sierra Chart Exchange Data Feed. You will find the information for this data feed along with the Setup Instructions here:
Or you can get the data from CQG since you are using CQG. Your broker can set you up with that.
Note that if you do activate the Sierra Chart Exchange Data Feed, since you are also using the Denali Exchange Data Feed, you will then receive a $12.00 USD per month credit to your account for having both of these activated.
Date Time Of Last Edit: 2020-05-16 00:05:59
