Date/Time: Thu, 06 Feb 2025 23:48:00 +0000
Trading Registration
View Count: 571
[2020-05-15 03:30:56] |
EMMANUEL B WALEOLA - Posts: 1 |
Need the link with which enroll for trading
[2020-05-16 02:42:39] |
We do not know what exactly you are referring to. Our best guess is that you mean the Sierra Chart Order Routing Service. Refer to the information here, which also has a Setup Instructions section that you can follow: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
