Date/Time: Thu, 06 Feb 2025 23:56:06 +0000
[Programming Help] - Static Linking of External Library
View Count: 616
[2020-05-15 00:21:49]
User617678 - Posts: 8
Would you please share with me compiler options to statically link a library?
Thank you
[2020-05-15 03:35:08]
Do you mean using Remote Build? That would not be supported. You would need to use Visual C++ for this.
[2020-05-15 03:38:12]
Yes I meant using Visual C++. I'm not a Windows users and not too familiar with the VC++ tooling. I saw there's a text box for compiler parameters and thought reaching out and see if there is any documentation regarding static linking.
Thank you
