Date/Time: Wed, 30 Sep 2026 01:29:15 +0000
Volume By Price and 1/Price study
View Count: 1657
| [2014-01-21 13:22:21] |
| corbeste - Posts: 74 |
Hi, Is it possible to combine the VbP and 1/price studies? I am unable to display the VbP study after using 1/Price as the main price chart (for various currency futures). Not sure if this is a scaling issue, but the Chart Region is identical (1) and the "Based on" field is set to the 1/Price study. Other studies seem to work fine. Thanks, Steve |
| [2014-01-21 13:27:31] |
What we recommend you do instead is adjust the Real-time and Historical Price Multipliers in Chart >> Chart Settings >> Advanced Settings 2 to accomplish the same thing as the 1/Price study.
| [2014-01-21 13:37:18] |
I'm not clear on what multiple to use - I am looking to invert the pair, and multiplying the price by a number wont help. Is it possible to divide via this field? |
| [2014-01-21 13:51:25] |
Thinking about this some more, there is not really a way to do an inverse calculation like the 1/Price study with the multipliers. So we have to add an option for this to Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-21 13:56:06] |
Ok, I hope you can get around to this soon. Its useful because the Yen and Peso futures are inverse to the standard quoting convention.
