Date/Time: Wed, 12 Feb 2025 18:20:02 +0000
Market Depth Historical Graph study for us stocks with Sierra Chart Service Package 5
View Count: 698
[2020-05-14 15:17:25] |
endinem - Posts: 4 |
Hi guys! Thanks for your great work. A quick question: Is it possible to use the Market Depth Historical Graph study for US stocks if I have chart service package 5 without having live data feed? I wasnt able to make it work so far unfortunately. If yes, how many levels are available? Thanks in advance! |
[2020-05-14 19:20:42] |
No, you cannot use the Market Depth Historical Graph with historical data only. Sierra Chart does not have any reliable sources of data now for Market Depth data for US stocks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-10 20:07:04] |
szdaniel1994 - Posts: 18 |
I see that it is not possible to use with historical data, but is it possible to use with US equity live data feed?
[2020-11-10 21:12:27] |
John - SC Support - Posts: 37910 |
Not with the Sierra Chart U.S. Equities, as we do not have the Level 2 Market Depth data.
