Date/Time: Fri, 07 Feb 2025 00:16:29 +0000
Sierra Trail
View Count: 644
[2020-05-14 15:01:32]
User419226 - Posts: 1
I am just testing SC. I need to be able to configure the Dom trader and Chart Dom to enter bracket orders with a target and trailing stop. I would also like to reverse the bracket when stopped. I can see how to set a simple bracket but not how to configure custom brackets to add stop and reverse. Is this possible?
Also in the Chart Dom I cant seem to get consistent scaling. I would like the scaling to match the products ticks. I'm currently trying the Dax and have set the scale range as independent and the scale increment to 0.5. I'm not sure Ive done this correctly as the scale can change depending on price movement.
[2020-05-14 20:17:56]
There is no way to use Attached Orders to create a reversal of position.
You would need to enter another Stop order at the level of the existing stop Attached Order to do the reversal.
With regards to the scaling, refer to this setting:
Chart Scale and Scale Adjusting: Scale Increment (Scale Settings)
And also the Constant Range options for scaling:
Chart Scale and Scale Adjusting: Constant Range (Scale Range)
