Date/Time: Thu, 06 Feb 2025 23:41:01 +0000
CFD data
View Count: 750
[2020-05-14 04:27:03] |
User884103 - Posts: 19 |
Hi, I am not able to load more than the 1 month of intraday CFD data for AUS200. I have checked chart settings 'number of days to load' is 220. Historical data is loading fine and other products such as futures data load normally in the same chart. Id be grateful for any assistance. Thank you Hanna |
CFD data example.Cht - Attached On 2020-05-14 04:25:48 UTC - Size: 87.86 KB - 320 views Attachment Deleted. |
[2020-05-14 07:40:54] |
There is a lot more data than that for that symbol. Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
