Date/Time: Thu, 06 Feb 2025 23:39:58 +0000
Messege Log
View Count: 553
[2020-05-13 16:59:42] |
User544164 - Posts: 6 |
Hola, buenos dias. Porfavor.ultimamente me sale e Message Log que no puedo usar algunas cosas de Studies to Graph y me dice que hasta que no lo retiro La sierra Chart puede estar unestable. Por ejemplo Studies NMinBars. Lo estoy utilizando anos y de repente me dice esto. Otro creo es VWap Bands. Pero lo mas que me preocupa es que me el Volume profile que estoy utilizando mucho. Ya dos veces se me desconecto Sierra chart para unas horas y no se porque. Tengo paquete 5 y siempre iba bien. Ya he enviado al support el message log pero es que no entiendo donde y con quien puedo comunicar. Salen links pero no encuentro la solucion. Me puede ayudar porfavor o dar un contacto a algienn que me dira por que esta haciendo esto? Y ahora mismo lo esta haciendo de nuevo. He sacado NminiBars pero no se. Ahora se desconecto otra vez ya dos horas y dice ... Connection error from servis: Rithmic Trading
[2020-05-13 19:03:36] |
Translation: Hello good day. Please, lately I get the Message Log that I can't use some of the Studies to Graph things and it tells me that until I remove it The Sierra Chart may be unstable. For example Studies NMinBars. I am using it for years and suddenly it tells me this. Another one I think is VWap Bands. But the most that worries me is that I get the Volume profile that I am using a lot. Twice already the Sierra chart was disconnected for a few hours and I don't know why. I have package 5 and it was always good I have already sent support the message log but I do not understand where and with whom I can communicate. Links come out but I can't find the solution. Can you please help me or give someone who will tell me why they are doing this? And right now he's doing it again. I have released NminiBars but I don't know. Now he logged out again two hours ago and says ... Connection error from servis: Rithmic Trading
[2020-05-13 19:55:09] |
Regarding the custom study exception issue, refer to the instructions here with what to do in regards to the User Contributed Studies: Notice: Study Exceptions in New Versions and Code Efficiency Regarding connectivity to Rithmic, Sierra Chart has discontinued support for Rithmic. Refer to: Regarding Rithmic (Our Final Post on this Subject) You will need to use an alternative service. That thread linked above, explains the alternatives. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-13 19:57:15
