Date/Time: Thu, 06 Feb 2025 23:26:03 +0000
menu font
View Count: 547
[2020-05-13 16:51:30] |
User766076 - Posts: 3 |
Hi I tried and looked for it but no idea where that is - I would like to change the text font size for the menu commands - like file, settings, etc. Have already changed the font size for everything except for this. Thanks in advance |
[2020-05-14 06:20:33] |
This is an operating system setting. So you need to go to your Windows operating system control panel and see where to change this.
