Date/Time: Mon, 25 Nov 2024 08:29:37 +0000
TOOL_TEXT - Potential Bug
View Count: 1664
[2014-01-21 05:59:24] |
ejtrader - Posts: 688 |
SC Team - There seems to be a potential bug with TOOL_TEXT. if DT_RIGHT is used it's aligning to LEFT and when DT_LEFT is used - it's aligning to RIGHT. Would you please review? Noticed this with SC Version - 1077. Tool.BeginDateTime = -1; Tool.TextAlignment = DT_RIGHT | DT_VCENTER; // This is marking the text to left Tool.TextAlignment = DT_LEFT | DT_VCENTER; // This is marking the text to Right In case if you are going to review this area - Would you please see if you can replicate following sub-graph feature to TOOL_TEXT as well - if it is reasonably easy to implement from technical stand point of view. If not - It's understandable that you are busy. Thanks sg1.LineLabel = LL_DISPLAY_VALUE | LL_VALUE_ALIGN_VALUES_SCALE | LL_VALUE_ALIGN_CENTER | LL_DISPLAY_NAME | LL_NAME_ALIGN_CENTER | LL_NAME_ALIGN_FAR_RIGHT; Date Time Of Last Edit: 2014-01-21 08:12:37
[2014-01-21 20:44:07] |
WarriorTrader - Posts: 245 |
Hello, It's been like that for a while. But if it is corrected, everyone will have to go back and edit their code. That would be a pain in the ... WT |
[2014-01-21 20:51:02] |
We will be looking all of this over. Our understanding is that DT_RIGHT will mean that the right side of the text is aligned to the point that you specify. So it will look like it is aligned to the left. The opposite for DT_LEFT alignment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-21 20:53:19
[2014-01-21 20:52:40] |
Agreed. If SC team can create a TOOL_SUBGRAPH ( a new tool text but with the below properties ) or include the below properties to existing TOOL_TEXT - that would be great as well in that case :) sg1.LineLabel = LL_DISPLAY_VALUE | LL_VALUE_ALIGN_VALUES_SCALE | LL_VALUE_ALIGN_CENTER | LL_DISPLAY_NAME | LL_NAME_ALIGN_CENTER | LL_NAME_ALIGN_FAR_RIGHT; Date Time Of Last Edit: 2014-01-21 20:53:37
[2014-01-21 20:53:35] |
Post #3 has been updated.
[2014-01-21 20:56:34] |
SC team - You don't have to make changes to DT_LEFT & DT_RIGHT. As WarriorTrader mentioned - it would mean forced code changes for others. However - if it is not too much of technical challenge - would it be possible to allow the similar properties of a sub-graph to TOOL_TEXT as well? ( label far right aligned & marker in values scale ). Thanks Date Time Of Last Edit: 2014-01-21 21:09:11
[2014-02-22 04:03:36] |
Profile Trader - Posts: 174 |
Warrior Trader can you contact me either at dougrkyle@yahoo.com or dougrkyle on skype Thanks Doug |
[2014-02-25 19:45:41] |
Doug, Send you an email. --WT |
