Date/Time: Thu, 06 Feb 2025 22:11:43 +0000
Tomasz
View Count: 521
[2020-05-13 12:24:07]
User695816 - Posts: 25
HI. I need help. my sierra chart, don't want to connect. I put money for it and nothing works here, it's not fair. CAN THOSE REPAIR SOMEONE !!!!!!PLEASE.
Reading Internal Order ID file. | 2020-05-13 14:22:44.370
Reading Trade Orders file. | 2020-05-13 14:22:44.547
Reading Trade Positions file. | 2020-05-13 14:22:44.549
Reading Account Balance file. | 2020-05-13 14:22:44.552
Subscribing to symbol for symbol alert. 6EM0-CME | 2020-05-13 14:22:44.557
Subscribing to symbol for symbol alert. FDXM0620-EUREX | 2020-05-13 14:22:44.558
Subscribing to symbol for symbol alert. FDXM0320-EUREX | 2020-05-13 14:22:44.559
UDPListener (964). Port 22904 | Listening on UDP port 22904. | 2020-05-13 14:22:44.609
Software version: 2102 64-bit | 2020-05-13 14:22:44.609
Primary Thread ID: 6080 | 2020-05-13 14:22:44.609
Usage end date: 2020-05-29 | 2020-05-13 14:22:44.609
Enabled for: Advanced Features 2. | 2020-05-13 14:22:44.609
Enabled for: Sierra Chart Historical Data Service. | 2020-05-13 14:22:44.609
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-05-13 14:22:44.609
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-05-13 14:22:44.609
Current selected Data/Trading service: Rithmic Trading | 2020-05-13 14:22:44.609
Custom symbol settings values: enabled | 2020-05-13 14:22:44.609
Chart Update Interval: 10 | 2020-05-13 14:22:44.609
Intraday Data Storage Time Unit: 0 | 2020-05-13 14:22:44.609
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2020-05-13 14:22:44.609
2020-05-13 13:22:44 Local computer time | 2020-05-13 14:22:44.609
2020-05-13 12:22:44 Local computer time in UTC | 2020-05-13 14:22:44.609
2020-05-13 14:22:44 Local computer time in SC Time Zone | 2020-05-13 14:22:44.609
2020-05-13 12:22:40 Server time in UTC | 2020-05-13 14:22:44.609
Local computer UTC time and Server UTC time difference: 3 seconds. | 2020-05-13 14:22:44.609
Program path: C:\SierraChart\ | 2020-05-13 14:22:44.609
Data Files path: C:\SierraChart\Data\ | 2020-05-13 14:22:44.609
OS Version Number: 6.3 | 2020-05-13 14:22:44.610
Locale Setting: C | 2020-05-13 14:22:44.610
DLLs: Breakout_Split_Profiles_for_BMT.dll, CustomVWAP.dll, Display Study as Numbers on Bottom v3 (2).dll, Display Study as Numbers on Bottom v3 (5).dll, Display Study as Numbers on Bottom v3.dll, Div_AVEC_jPtH_V_1.dll, Dom_on_Chart.dll, Dom_on_Chart2.dll, Dom_Size_for_Dom64.dll, ECIDeltaV0.4.dll, ECIVwapV0.2.dll, ECIVwapV0.7.dll, ECIVwapV1.2.dll, EngulfingBaroption_Vline.dll, EngulfingBar_Vline.dll, ExtractQuantData.dll, fband.dll, HighVAP.dll, icebergdetector.dll, icudt52.dll, icuin52.dll, icuuc52.dll, new4.dll | 2020-05-13 14:22:44.612
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-05-13 14:22:44.655
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-05-13 14:22:44.755
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-05-13 14:22:44.788
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-05-13 14:22:44.788
Received 5 login tokens. | 2020-05-13 14:22:44.815
Symbol settings MD5 received. Request ID: 1. | 2020-05-13 14:22:44.998
Symbol settings are up-to-date for rithmic.trading. | 2020-05-13 14:22:44.998
Rithmic Trading | Port for executable: 64731 | 2020-05-13 14:22:49.914
Listening socket (980). Port 64731 | Closed. | 2020-05-13 14:22:49.914
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-05-13 14:22:49.915
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64731. Current folder: C:\SierraChart\Rim | 2020-05-13 14:22:49.939
Rithmic Trading | Bridge process is running. | 2020-05-13 14:22:51.928
Rithmic Trading | Connecting to the server 127.0.0.1. Port 64731 | 2020-05-13 14:22:51.928
DTC Client socket (1) | Creating socket. | 2020-05-13 14:22:51.928
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-05-13 14:22:51.928
Rithmic Trading | Connected to server. | 2020-05-13 14:22:51.931
Rithmic Trading | Starting socket receive thread. | 2020-05-13 14:22:51.931
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-05-13 14:22:51.932
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-05-13 14:22:51.935
Rithmic Trading | Sending logon request message. | 2020-05-13 14:22:51.935
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-05-13 14:22:51.938
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-05-13 14:22:51.940
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-05-13 14:22:51.940
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-05-13 14:22:53.147
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2020-05-13 14:22:53.249
Rithmic Trading | Received logon response. | 2020-05-13 14:22:53.249
Rithmic Trading | Server Name: DTC Bridge. | 2020-05-13 14:22:53.249
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-05-13 14:22:53.249
Rithmic Trading | Logon error received from server | 2020-05-13 14:22:53.249
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-05-13 14:22:53.249
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-05-13 14:22:53.249
DTC Client socket (1) | CloseSocket call. | 2020-05-13 14:22:53.295
Rithmic Trading | Disconnected. | 2020-05-13 14:22:53.296
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-05-13 14:22:53.296
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-05-13 14:22:53.296
Rithmic Trading | Port for executable: 64741 | 2020-05-13 14:22:55.291
Listening socket (984). Port 64741 | Closed. | 2020-05-13 14:22:55.291
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-05-13 14:22:55.294
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64741. Current folder: C:\SierraChart\Rim | 2020-05-13 14:22:55.315
Rithmic Trading | Bridge process is not running! | 2020-05-13 14:22:57.303
Rithmic Trading | Connecting to the server 127.0.0.1. Port 64741 | 2020-05-13 14:22:57.303
DTC Client socket (2) | Creating socket. | 2020-05-13 14:22:57.303
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-05-13 14:22:57.303
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-05-13 14:22:58.304 *
DTC Client socket (2) | CloseSocket call. | 2020-05-13 14:22:58.304
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-05-13 14:22:58.304
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-05-13 14:22:58.304
DTC Client socket (2) | Closed. | 2020-05-13 14:22:58.304
DTC Client socket (0) | CloseSocket call. | 2020-05-13 14:22:58.319
Rithmic Trading | Disconnected. | 2020-05-13 14:22:58.319
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-05-13 14:22:58.319
Rithmic Trading | Port for executable: 64743 | 2020-05-13 14:23:00.390
Listening socket (1000). Port 64743 | Closed. | 2020-05-13 14:23:00.391
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-05-13 14:23:00.392
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64743. Current folder: C:\SierraChart\Rim | 2020-05-13 14:23:00.397
Rithmic Trading | Bridge process is not running! | 2020-05-13 14:23:02.412
Rithmic Trading | Connecting to the server 127.0.0.1. Port 64743 | 2020-05-13 14:23:02.412
DTC Client socket (2) | Creating socket. | 2020-05-13 14:23:02.413
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-05-13 14:23:02.413
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-05-13 14:23:03.428 *
DTC Client socket (2) | CloseSocket call. | 2020-05-13 14:23:03.429
DTC Client socket (2) | Closed. | 2020-05-13 14:23:03.429
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-05-13 14:23:03.429
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-05-13 14:23:03.429
DTC Client socket (0) | CloseSocket call. | 2020-05-13 14:23:03.444
Rithmic Trading | Disconnected. | 2020-05-13 14:23:03.444
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-05-13 14:23:03.444
Rithmic Trading | Port for executable: 64745 | 2020-05-13 14:23:05.448
Listening socket (1000). Port 64745 | Closed. | 2020-05-13 14:23:05.448
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-05-13 14:23:05.450
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:64745. Current folder: C:\SierraChart\Rim | 2020-05-13 14:23:05.472
Rithmic Trading | Bridge process is not running! | 2020-05-13 14:23:07.459
Rithmic Trading | Connecting to the server 127.0.0.1. Port 64745 | 2020-05-13 14:23:07.459
DTC Client socket (2) | Creating socket. | 2020-05-13 14:23:07.459
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-05-13 14:23:07.460
