Date/Time: Mon, 25 Nov 2024 06:24:36 +0000
Charting a specific historical date range
View Count: 1372
[2014-01-21 03:58:02] |
Willson - Posts: 176 |
Assuming I have proper data files, how can I select say 1 month from 2013 (or one day)and view the chart book? Regards |
[2014-01-21 13:26:10] |
For a historical Daily chart or Intraday chart?
[2014-01-21 17:15:04] |
my charting is intraday. My data files are IQ feed, and are the continous feed symbology with the @ prefix. Thanks |
[2014-01-22 08:36:39] |
Therefore, you can specify a specific date range in the Chart >> Chart Settings window.
