Date/Time: Thu, 06 Feb 2025 23:15:50 +0000
GetStudyPeakValleyLine() without drawing the lines for peaks/valleys
View Count: 1007
[2020-05-13 04:49:29] |
QnReally - Posts: 181 |
I am retrieving peak/valley line prices from several Volume By Price studies. However, I am trying to figure out a way to not display the peak/valley lines for the VBP. I have tried several options but all of them draw the peak/valley lines: 1) Draw Peaks & Valleys input = "Both Peaks & Valleys", 2) Extend Peaks & Valleys input = there is no "None" option here. 3) Volume Peaks and Volume Valleys subgraphs = there is no option to not display the lines (if I set the Draw Style to "Ignore" I still see the lines) Can you please make a suggestion? I need the VBP studies to retrieve the peak/valley prices but my chart has become cluttered with too many lines. Thanks. |
[2020-05-13 05:27:40] |
So you just want them calculated but you do not want to actually visibly see the Peak and Valley lines?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-13 05:27:46
[2020-05-13 13:10:19] |
That is exactly right. Thanks.
[2020-05-13 20:18:50] |
We will see if we can add this.
