Date/Time: Thu, 06 Feb 2025 22:17:18 +0000
ECIVwap problem
View Count: 704
[2020-05-12 22:16:37] |
navigator - Posts: 27 |
I have the same problem others have had with the ECIVwap study. I installed SC 2102 with the install optional components. I show ECIVwap V1.5 and everything ok, until I close SC, reopen, and it reverts to ECIVwap V1.4. I've done this with opening only 1 chart with no studies on it,(so no old studies of ECIVwap 1.4 on it) and it still reverts to V1.4, in the User Contributed Studies section. Also get that "Warning: The Custom DLL study "UserContributedStudies_64.scsf_ECIVwap" has just caused a CPU exception. Help!.
[2020-05-13 04:11:24] |
This would mean that you still have an old UserContributedStudies_64.dll file. There is no other possibility. Update Sierra Chart again and enable Install Optional Components: Software Download: Fast Update And make sure you update the main instance of Sierra Chart and not the sub instances. Those will get updated automatically when restarted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-13 15:50:22] |
It seems I still had the older SC 32 bit application still installed and it was reverting to that, (probably not good in general). Once deleted, everything good now. Thank you.
