Date/Time: Thu, 06 Feb 2025 22:15:44 +0000
Regarding Filled Child Order labels from an Attached Order
View Count: 474
[2020-05-12 21:30:57]
Michael W - Posts: 20
It appears that all labels for filled Child orders contain the word "open". When attached orders and the child limits and stops are set are they not to "close" the order? Whether you get stopped out or take profit? I have been looking anywhere in Sierra Chart where this can be modified. Why? Because there are times when chart trading I have some limit orders to open a trade and I may also have some child filled (from attached orders) that are in use to close the trade. Distinguishing them can be at times confusing when they are all labeled "Open"
Is there any way to modify the text for Open and Close? It seems that every order says open. I have scoured Sierra Chart documentation and I cannot find a way to create or modify this distinction. Or if it is even possible.
Thanks for your help.
[2020-05-12 21:37:13]
If you are referring to the Open/Close field, we do not observe this. It is set correctly. You can do testing in Trade Simulation Mode:
Trade Simulation
