Date/Time: Thu, 06 Feb 2025 20:45:14 +0000
Chartbook Crashing
View Count: 662
[2020-05-11 22:49:55] |
User967628 - Posts: 5 |
I have a problem that started over the weekend. Every time I try to open a chartbook that I created ( it`s labeled PROFILE Scalping Chart ) it crashes all my other Sierra Chart chartbooks that are open. I have to then go back in, log on and re-open Sierra Charts again. Any help with this matter would be greatly appreciated. Please advise. Thanks in advance.
[2020-05-12 00:07:09] |
We are not certain what is exactly meant by "crashes", but refer to this help topic: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Also refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
